• Support
  • subdomain is always redirected to domain
i have apache and php7.2, php 7.3 and php 7.4 installed
I have several subdomains working perfectly, but now I'm trying to add a new subdomain and it doesn't want to work, it always goes to the home of the domain I have. I delete them and recreate them and the same thing always happens, I don't understand what happens this happened from one moment to the next.
I always add them as a new website. but I don't understand why after having several subdomains working, now it doesn't allow me to add more.
the other subdomains are working perfectly, the problem is when I want to add a new one.
I appreciate the help you can give me.
    5 days later
    It would be very helpful for me to know your opinion about it, I have not been able to re-create subdomains in any way.
      • [deleted]
      colvengroup Do you have in aapanel configure SSL certificates for all of the domain name?
      10 days later
      colvengroup
      i had this problem today and fixed it
      if you have SSL/TLS encryption mode in cloudflare as full strict make sure to generate ssl certificate even for subdomains at aapanel
      or set SSL/TLS encryption mode to flexible and all subdomains will work again like they used to
      10 months later
      3 years later
      I was having same issue. I am also using cloudflare ssl. My problem fix by using same ssl for subdomain which i was using for main/parent domain. in this way my subdomain issue fixed.
