FTP Storage App:
So I downloaded the FTP Storage app (Not PureFTPd) thinking it will allow me to add remote Storage adding FTP details. But, it always shows me a Connection error. Is it only for the the internal usage?
    I just installed FTP Storage on and it works
    (centos 7+ PureFTPd, PHP...)
    zohebnsr
    Please check whether the ftp connection information you provided is correct?
    Or try to connect using ftp client on pc to see if it can be connected
      aaPanel_Jose I tried connecting via Filezilla and it got connected. I am trying to connect to BunnyCDN Storage that allows FTP with port 21 only.
      Just to test, I tried FTPStorage to connect to my FTP Users under AA Panel Account (Same host), and it got connected without any problem. So it's BunnyCDN where it is not connected to. I asked Bunny CDN if they can add Port 22 support. They said, no it's not possible. Their connection type shows as "Passive" under storage API Detail. Not sure if it has something to do.
      aaPanel_Jose I am getting Error API verification failed. But, I can connect via Filezilla to BunnyCDN. What could be wrong here? I have the API key, but not sure if it can be used somewhere under AA Panel.
        aapanel_user Filezilla works. But I doubt that Passive mode is the problem, Hope AAPanel's FTP add support for Passive Connection.
        2 years later
        check sftp option in the plugin and it works. I had connected and backup is perfectly working.
