• Support
  • PHP 8 is not shown under website settings
Hi
I have installed PHP8 to test it, but when I tried to switch PHP version, there is no PHP 8 under any website settings. Can you please check?
    szone i think this is bug...
    i try to reinstall my centos to new and reinstall the aapanel
    after that... all works...
    before it... i have same problem like you....
    i dont know why and how it appear... but now it done...
    maybe you can try it for your last hope XD
      Dhanamerdeka Ahh, thanks for the tip. But it's not possible to reinstall the server, as it will take quite a long time to configure it again according to my setup. So this bug should be fixed.
