• Support
  • fail2ban - how to add multiple scan rules?
I was wondering if I can add multiple dirs or files to the scan rule, since I cannot create more than one. For example, I would like to create xmlrpc.php and wp-login.php on one audit. Is this possible, or any alternative ?
5 days later
wizzy
Sorry currently does not support adding multiple conditions to one configuration
4 days later
Another problem I also encountered is that when I try to set blacklist or whitelist it takes forever to load, but loads eventually (after around 10 minutes). Is this normal?
