aaPanel_Jose Change Log: Fixed the setting error of php session under certain circumstances Fixed the issue of automatically applying for SSL if you didn’t check the box when creating a website Fix apache https anti-generation problem Optimize the default log format of OLS Optimize the Nginx reverse proxy string replacement function
jenniferlopse aaPanel_Jose Now PHP session storage shows "Please install the memcached extension first." "Please install the redis extension first." I already installed redis and memcached. I updated to latest Beta and fixed the panel... But no luck. Please help me
JAY from beta to beta update not working i need to fix panel and goback to stable version and update beta to get latest beta
aaPanel_Jose JAY I just tested the upgrade and there is no problem. Have you tried restarting the panel?
