aaPanel_Jose JAY Your problem is that mysql has a lot of update statements in execution. you need to troubleshoot the program or if you try to restart mysql
JAY aaPanel_Jose it was not happening before only after update tried restart and even upgraded sql to mariadb latest version.
jazz1611 @aaPanel_Jose hello, i know it related to SSL port limit. i was integrated the vDDoS (https://github.com/duy13/vDDoS-Protection) to aaPanel with (https://github.com/duy13/vDDoS-Auto-Add) and working fine with good DDoS Protection. vDDoS-Protection is frontend, Nginx or Apache is backend. if you can make custom port as default when add site is great!!!
aaPanel_Jose jazz1611 If deploying ssl allows custom ports, it may cause problems for other users, let me consider
aaPanel_Jose JAY emmm, but the panel does not actively connect to mysql, you try to stop the panel run bt stop(will not affect your business), and then observe whether the mysql load has dropped
aaPanel_Jose JAY The uploaded database file will be stored here, delete the corresponding file. /www/backup/database We will add the delete button as soon as possible.
