aaPanel_Jose
â— pdns.service - PowerDNS Authoritative Server
Loaded: loaded (/usr/lib/systemd/system/pdns.service; enabled; vendor preset: disabled)
Active: active (running) since Wed 2020-10-14 10:28:36 +03; 6s ago
Docs: man:pdns_server(1)
man:pdns_control(1)
https://doc.powerdns.com
Main PID: 21665 (pdns_server)
CGroup: /system.slice/pdns.service
└─21665 /usr/sbin/pdns_server --guardian=no --daemon=no --disable-syslog --log-timestamp=no --write-pid=no
Oct 14 10:28:36 srv1.pervero.com pdns_server[21665]: PowerDNS Authoritative Server 4.1.14 (C) 2001-2018 PowerDNS.COM BV
Oct 14 10:28:36 srv1.pervero.com pdns_server[21665]: Using 64-bits mode. Built using gcc 4.8.5 20150623 (Red Hat 4.8.5-39).
Oct 14 10:28:36 srv1.pervero.com pdns_server[21665]: PowerDNS comes with ABSOLUTELY NO WARRANTY. This is free software, and you are welcome to redistribute it according to the terms of the GPL version 2.
Oct 14 10:28:36 srv1.pervero.com pdns_server[21665]: Creating backend connection for TCP
Oct 14 10:28:36 srv1.pervero.com pdns_server[21665]: [bindbackend] Parsing 1 domain(s), will report when done
Oct 14 10:28:36 srv1.pervero.com pdns_server[21665]: [bindbackend] Done parsing domains, 0 rejected, 1 new, 0 removed
Oct 14 10:28:36 srv1.pervero.com systemd[1]: Started PowerDNS Authoritative Server.
Oct 14 10:28:36 srv1.pervero.com pdns_server[21665]: About to create 3 backend threads for UDP
Oct 14 10:28:36 srv1.pervero.com pdns_server[21665]: Done launching threads, ready to distribute questions
Oct 14 10:28:36 srv1.pervero.com pdns_server[21665]: Exception building answer packet for santral.xyz/A (Parsing record content (try 'pdnsutil check-zone'): while parsing IPv6 address, expected xdigits at position 0 in '[2001:19f0:5001:2a0f:5400:3ff:fe02:f8ae]') sending out servfail
