Extremely slow loading during (aaPanel) installation, it's spends more than 8 working hours for installation
Over the past few days, I have installed the server's control panel (aaPanel) more than 10 times.
I found the following:
  1. The panel does not accept other resources installed via SSH, such as:
  2. MySQL (all versions),
  3. Apache,
  4. phpMyadmin,
  5. PHP files,
  6. FTP.
They must be downloaded and installed via the (aaPanel) control panel (which I believe is a great, useful feature for everyone).
  1. If the aforementioned resources are installed via SSH, they conflict with the resources installed by the control panel, causing malfunctions in script execution and site management.3- The (aaPanel) is extremely slow to load. To clarify, the  (aaPanel)  took about 20 minutes for installation & setup.other resources:
    MySQL 8.0.36 took 4.5 hours.
    Nginx 1.24.0 + Pure-Ftpd 1.0.49 + phpMyAdmin 5.2 + PHP-8.3 took about 3 hours.
    Total of more than: 8 hours waiting to complete installation.
4- When installing PHP-8.3, many necessary libraries, such as [calendar], are not automatically or by default installed. They must be downloaded and run manually through the (aaPanel) PHP control menu.
5- I believe the server's of operating systems should be updated before starting the (aaPanel) files download & installation process.
6- I think it's a good idea to enable swap files on your server before start up installation. and I recommends it's very necessary, regardless of whether the RAM is less than 4GB or more.
My Note:
I believe the  (aaPanel)  installation system collects files on the server from remote and very slow servers, and then installs them on the client's server. This is the reason for the extreme slowness. Therefore, there should be dedicated distributions for the (aaPanel) .
The (aaPanel)  is beautiful, wonderful, and modern, and its services are seamless. It deserves more.
    Hello,
    aaPanel only supports the management of software installed from the App Store, and does not support the management of software installed using apt/yum/dnf
    Thank you for your feedback, can you provide the following information to us?
    1. What is the hardware configuration of your server?
    2. What version of the operating system is?
    3. What is the CPU architecture?
    4. What is the region where the server is located?
    5. Is there an installation log file: /tmp/panelExec.log can send it to us
    aaP_aboayoob
      1- What is the hardware configuration of your server?
      Armour, 2vCPU, RAM 4GB, local Disk 40GB
      2- What version of the operating system is?
      ubuntu 22.04 server,
      3- What is the CPU architecture?
      ARM's
      4- What is the region where the server is located?
      Germany
      4- Is there an installation log file: /tmp/panelExec.log can send it to us
      too much lines
        Hello,
        Thank you for your feedback, ARM's current software installation basically takes a long time to compile and install.
        But we don't have the long time here, and this may also affect the download.
        aaP_aboayoob
        When I searched, asked, and inquired with the hosting company, they told me that ARM's was better than Intl 86 ...
        So I chose... I think it is the most suitable.
        Hello,
        Currently, the arm compatibility is relatively low in software, so we will optimize it later.
