I added domain.com and www.domain.com as sites, it works normally, can be accessed with and without www
Then, on another site, let's say domain2.com, I added *.domain.com
Yes, that's right, I use the wildcard from *.domain.com on the domain2.com site, not on the domain.com site
So, I have 2 sites, domain.com and domain2.com
I put the wildcard from *.domain.com into the domain2.com site domain list, of course because that's my need.
However, there is 1 problem that arises.
domain.com is normal, but www.domain.com is directed to the domain2.com site
As if the Panel prioritizes the Wildcard (*), then the subdomain (www).
even though www.domain.com has also been registered on the domain.com site domain
Is there a solution? or maybe it can be fixed in the next update
