I have been having issues for a lot of time maybe a year where auto renewal of ssl does not work . Now I see you have added another cron renew_3 but that also does not work
/www/server/panel/pyenv/bin/python3 -u /www/server/panel/class/acme_v2.py --renew_v3=1
File "/www/server/panel/class/public/aaModel/manager.py", line 599, in __index_exists
cur = self.__query.query(f"PRAGMA index_list({self.__table});")
File "/www/server/panel/class/public/sqlite_easy.py", line 2196, in query
ret = self.__DB.client().query(raw_sql, _to_tuple(params), take_first)
File "/www/server/panel/class/public/sqlite_easy.py", line 1056, in query
ret = self.__sqlite_retry_help(self.__query_help, sql, params, take_first)
File "/www/server/panel/class/public/sqlite_easy.py", line 1020, in __sqlite_retry_help
return fn(*args, **kwargs)
File "/www/server/panel/class/public/sqlite_easy.py", line 1086, in __query_help
ret = _format_cursor(cur)
File "/www/server/panel/class/public/sqlite_easy.py", line 127, in _format_cursor
cols = tuple(map(lambda x: x[0], cursor.description))
TypeError: 'NoneType' object is not iterable
Old script renew=1 is not detecting that there is ssl less than 30 days
Is there any solution to this ssl renewal?
