I am using a code on one Domain Example.com hosted on aapanel , in which We let user to create their online stores, we let them use their own custom Domains.
Now the problem is When we apply ssl once, ut works fine but when we add other domain then there is no option rather than Disabling ssl on all domains and re apply for ssl again.
Please help me adding domains ssl without disturbing others.
this image is of before applying ssl , after applying we got no option to appply ssl to other domain.
    Hello, it is recommended that you try to create a new site for different domain names, the site directory is the same, and then apply for SSL
    Current SSL certificates Let's Encrypt not support multiple domain names
    aaP_ashutoshjha629
    aaP_ashutoshjha629 You go to websites list, click add , enter the domain name and on the Website Path
    you place the same path that is running your backend , example /www/wwwroot/mycrmfolder, this way you can individually setup ssl and other stuff .
