- Edited
I have a project where I need to use a single domain for two websites: one for a Laravel application and another for a Node.js application.
This setup is possible with cPanel, but can it also be achieved with aaPanel?
Hello, you can configure the reverse proxy of the directory to implement
aaPanel_Kern can you tell more details? i don't understand yet
Hello, you can use different directories or subdomain implementation
aaPanel_Kern I am using the same directory structure.
The Laravel folder is in the /core directory,
and I use /core/index.js to run Node.js.
Hello, you can test the deployment
