• Support
  • Manual extension installation
Good evening
I need to install these extensions in the PHP 8.1 dashboard because I couldn't find them in the extensions section. If you can help me, how do I install them? I thank you in advance. The extensions are listed below.
yaf
phalcon
pgsql
Hello, pgsql has been replaced with pdo_pgsql. Other plugins require you to manually compile and install them.
