Hello, I need to import one file using phpmyadmin, how should I do it? Can you give me some instructions?
I downloaded the php game platform and I need to import the file game_portal.sql file by using phpmyadmin.
Because without it the website will not work. It would be best if someone had screenshots.
Thank you for your help
    Hello, can you find the corresponding database import from the Databases interface?
    aaP_codybsm
