aaPanel_Kern Hello, please find mysql in the App Store and check the current load and slow log. Or use PHPmyadmin to view monitoring and check all processes and check the causes. naijawide
naijawide aaPanel_Kern have checked it i can't find current load, please how can i drop my details so u can help me, have been battling with this since yesterday and it already affecting my business
aaPanel_Kern This shows the slow log. Is there any Current status information? Is there any information that phpmyadmin can view? naijawide
aaPanel_Kern Hello, is it possible to try to increase the performance configuration of Mysql? It is recommended to use phpmyadmin to check naijawide
naijawide aaPanel_Kern i have like 5 websites, should i do the same. Before my core was 8 due to this issue i buy more now 12, still the same
aaPanel_Kern Have you adjusted the configuration of mysql? You need to check which SQL statement is causing the problem first. Also check whether any functions/plug-ins have been added to the website recently? naijawide
