Cos_404 Hello everyone, I'm stuck here, can anyone help? I’ve tried modifying the config.inc.php file, but it didn’t work. thanks Coslow
aaP_demo1 Cos_404 If you're using PHP83, try install mbstring extension and restart PHP service or using with PHP82
aaPanel_Kern Hello, is the problem solved? If you use PHP8.3, please install the Mbstring extension. You can also try to replace PHP8.2 Cos_404
