• Support
  • I can not connect my local terminal with aapanel
i was connect my git hub account by shh after connected my local terminal not working and show error like this
when i trying to connect my terminal
error in termainal
{'result': 'unknown error: Traceback (most recent call last):\n File "/www/server/panel/class_v2/ssh_terminal_v2.py", line 176, in connect\n pkey = paramiko.RSAKey.from_private_key(p_file)\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File "/www/server/panel/pyenv/lib/python3.12/site-packages/paramiko/pkey.py", line 442, in from_private_key\n key = cls(file_obj=file_obj, password=password)\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File "/www/server/panel/pyenv/lib/python3.12/site-packages/paramiko/rsakey.py", line 61, in __init__\n self._from_private_key(file_obj, password)\n File "/www/server/panel/pyenv/lib/python3.12/site-packages/paramiko/rsakey.py", line 200, in _from_private_key\n data = self._read_private_key("RSA", file_obj, password)\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File "/www/server/panel/pyenv/lib/python3.12/site-packages/paramiko/pkey.py", line 526, in _read_private_key\n data = self._read_private_key_openssh(lines[start:end], password)\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File "/www/server/panel/pyenv/lib/python3.12/site-packages/paramiko/pkey.py", line 627, in _read_private_key_openssh\n raise PasswordRequiredException(\nparamiko.ssh_exception.PasswordRequiredException: private key file is encrypted\n\nDuring handling of the above exception, another exception occurred:\n\nTraceback (most recent call last):\n File "/www/server/panel/class_v2/ssh_terminal_v2.py", line 184, in connect\n pkey = paramiko.Ed25519Key.from_private_key(p_file)\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File "/www/server/panel/pyenv/lib/python3.12/site-packages/paramiko/pkey.py", line 442, in from_private_key\n key = cls(file_obj=file_obj, password=password)\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File "/www/server/panel/pyenv/lib/python3.12/site-packages/paramiko/ed25519key.py", line 65, in __init__\n signing_key = self._parse_signing_key_data(data, password)\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File "/www/server/panel/pyenv/lib/python3.12/site-packages/paramiko/ed25519key.py", line 98, in _parse_signing_key_data\n raise PasswordRequiredException(\nparamiko.ssh_exception.PasswordRequiredException: Private key file is encrypted\n\nDuring handling of the above exception, another exception occurred:\n\nTraceback (most recent call last):\n File "/www/server/panel/class_v2/ssh_terminal_v2.py", line 192, in connect\n pkey = paramiko.ECDSAKey.from_private_key(p_file)\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File "/www/server/panel/pyenv/lib/python3.12/site-packages/paramiko/pkey.py", line 442, in from_private_key\n key = cls(file_obj=file_obj, password=password)\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File "/www/server/panel/pyenv/lib/python3.12/site-packages/paramiko/ecdsakey.py", line 124, in __init__\n self._from_private_key(file_obj, password)\n File "/www/server/panel/pyenv/lib/python3.12/site-packages/paramiko/ecdsakey.py", line 287, in _from_private_key\n data = self._read_private_key("EC", file_obj, password)\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File "/www/server/panel/pyenv/lib/python3.12/site-packages/paramiko/pkey.py", line 526, in _read_private_key\n data = self._read_private_key_openssh(lines[start:end], password)\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File "/www/server/panel/pyenv/lib/python3.12/site-packages/paramiko/pkey.py", line 627, in _read_private_key_openssh\n raise PasswordRequiredException(\nparamiko.ssh_exception.PasswordRequiredException: private key file is encrypted\n\nDuring handling of the above exception, another exception occurred:\n\nTraceback (most recent call last):\n File "/www/server/panel/class_v2/ssh_terminal_v2.py", line 208, in connect\n pkey = paramiko.DSSKey.from_private_key(p_file)\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File "/www/server/panel/pyenv/lib/python3.12/site-packages/paramiko/pkey.py", line 442, in from_private_key\n key = cls(file_obj=file_obj, password=password)\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File "/www/server/panel/pyenv/lib/python3.12/site-packages/paramiko/dsskey.py", line 64, in __init__\n self._from_private_key(file_obj, password)\n File "/www/server/panel/pyenv/lib/python3.12/site-packages/paramiko/dsskey.py", line 232, in _from_private_key\n data = self._read_private_key("DSA", file_obj, password)\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File "/www/server/panel/pyenv/lib/python3.12/site-packages/paramiko/pkey.py", line 526, in _read_private_key\n data = self._read_private_key_openssh(lines[start:end], password)\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File "/www/server/panel/pyenv/lib/python3.12/site-packages/paramiko/pkey.py", line 627, in _read_private_key_openssh\n raise PasswordRequiredException(\nparamiko.ssh_exception.PasswordRequiredException: private key file is encrypted\n'}
    Hello, does the SSH key you use require a password to be used? Is it okay to try adding one?
    aaP_ind9546
