aaPanel_Kern i reloaded nginx server but it does not work i also tried to apply ssl on a new website but when i apply it gives error for acme challenge link it returns 404 from nginx
following is my config in nginx
#config
server
listen 80;
server_name somedomain.com;
root /www/wwwroot/somedomain.com;
#CERT-APPLY-CHECK--START
# Configuration related to file verification for SSL certificate application - Do not delete
include /www/server/panel/vhost/nginx/well-known/somedomain.com.conf;
#CERT-APPLY-CHECK--END
#error_page 404/404.html;
#SSL-END
error_page 404 /404.html;
error_page 502 /502.html;
#ERROR-PAGE-END
include enable-php-80.conf;
#PHP-INFO-END
include /www/server/panel/vhost/rewrite/somedomain.com.conf;
#REWRITE-END
location ~ ^/(\.user.ini|\.htaccess|\.git|\.env|\.svn|\.project|LICENSE|README.md)
return 404;
location ~ \.well-known{
allow all;
#Prohibit putting sensitive files in certificate verification directory
if ( $uri ~ "^/\.well-known/.*\.(php|jsp|py|js|css|lua|ts|go|zip|tar\.gz|rar|7z|sql|bak)$" ) {
return 403;
expires 30d;
error_log /dev/null;
access_log /dev/null;
location ~ .*\.(js|css)?$
expires 12h;
access_log /www/wwwlogs/somedomain.com.log;
error_log /www/wwwlogs/somedomain.com.error.log;
