hello @aaPanel_Kern
i do command on terminal storage is 38G
sudo du -ah --max-depth=1 / | sort -rh
du: cannot access '/proc/1830158/task/1830158/fd/4': No such file or directory
du: cannot access '/proc/1830158/task/1830158/fdinfo/4': No such file or directory
du: cannot access '/proc/1830158/fd/3': No such file or directory
du: cannot access '/proc/1830158/fdinfo/3': No such file or directory
du: cannot access '/proc/1830240/map_files/41810000-51810000': No such file or directory
38G /
23G /www
8.3G /var
3.4G /usr
2.3G /snap
1.2G /lib
415M /root
168M /boot
41M /tmp
18M /sbin
17M /bin
9.2M /etc
7.7M /home
1.3M /run
388K /path
20K /dev
16K /opt
16K /lost+found
16K /.Recycle_bin
8.0K /patch
4.0K /srv
4.0K /mnt
4.0K /media
4.0K /lib64
4.0K /.pearrc
0 /vmlinuz.old
0 /vmlinuz
0 /sys
0 /proc
0 /initrd.img.old
0 /initrd.img
but on status show 59G
it do after i delete
rm -rf /root/.pm2/logs/*
