Hello, this is my first time using aaPanel, and I want to ask several question about project deployment:
  1. I have 2 project, backend project with Express, and frontend with React, Is there any best way to deploy these app?
  2. How can I update my project that have been deployed?
Thank you
Hello, it is recommended that you refer to the official manual for deployment. There are currently some problems with aapanel's Node project.
But you can install Node.js directly in aapanel
