aaP_albraky2007 Problem adding domain aawaf nginx: [warn] the "listen ... http2" directive is deprecated, use the "http2" directive instead in /etc/nginx/vhost/0.default.conf:4
aaPanel_Kern Hello, is it possible to solve the problem by executing the following command? docker rm -f cloudwaf_nginx docker rmi btwaf-openresty:latest curl -k https://node.aapanel.com/cloudwaf_en/scripts/update_cloudwaf_en.sh |bash aaP_albraky2007
