Greetings!
After installing the latest Beta versions of the panel, FastCGI-Cache cleaning function stopped working correctly. The plugin in WP does not clean the /www/server/fastcgi_cache folder, also the folder is not cleaned if you click Clean in WP Toolkit. I always have to delete all folders manually via file manager.
Also, I would like to get instructions on how to get this cache back to the RAM partition? (/dev/shm), maybe it will be useful for someone in a particular case.
Or maybe even give a person a choice where to store this cache, in memory or on disk.
I am currently using panel version 7.19.0
