• Discussion
  • After Installing on Ubuntu 24.04, SSL certificate not issued to aaPanel.
Hi,
After Installing Fresh aaPanel on Ubuntu 24.04, SSL certificate not issued to aaPanel.
Can anyone tell me what i have to do to get the certificate?
I have checked in Settings, Panel SSL is enabled.
    Hello, aapanel installation uses a self-signed certificate by default. What certificate did you choose?
    It is recommended that you create a subdomain website in your website, then the A record of the subdomain points to the IP of the server, and then apply for SSL
    Finally, copy the contents of the certificate to Panel SSL, and then use the subdomain name to access the panel. No need to bind domain name
    aaP_abitouch
    I didn't choose any certificate, this is a fresh installation.
    And after installation when i am tried to open panel using IP it is not connecting with HTTPS.
      No, its showing Not Secure, if i open with https also.
      Hello, this is normal, the browser using the self-signed certificate by default does not trust it.
      You can refer to the above operations to
