I pressed on Mail Server and i got this error.
I tried also Beta version but same error.
REQUEST_DATE: 2024-11-30 17:17:05
VERSION: Ubuntu 22.04.2 LTS x86_64(Py3.12.3) - 7.19.0
REMOTE_ADDR: 178.23.xxx.xxx
REQUEST_URI: POST /v2/plugin?action=a&name=mail_sys&s=check_mail_env
REQUEST_FORM: {}
USER_AGENT: Mozilla/5.0 (X11; Linux x86_64; rv:120.0) Gecko/20100101 Firefox/120.0
`Traceback (most recent call last):
File "/www/server/panel/plugin/mail_sys/mail_sys_main.py", line 587, in init
self._sync_blacklist_to_unsubscribe_db()
File "/www/server/panel/plugin/mail_sys/mail_sys_main.py", line 5388, in _sync_blacklist_to_unsubscribe_db
with public.S("mail_unsubscribe", "/www/vmail/mail_unsubscribe.db") as obj:
File "/www/server/panel/class/public/common.py", line 117, in S
query = Db(db_name).query()
File "/www/server/panel/class/public/sqlite_easy.py", line 1268, in init
self.__connect()
File "/www/server/panel/class/public/sqlite_easy.py", line 1286, in connect
self.DB_CONN = DbConnection(self.__DB_NAME)
File "/www/server/panel/class/public/sqlite_easy.py", line 871, in init
self.connect()
File "/www/server/panel/class/public/sqlite_easy.py", line 916, in connect
self.CONN = sqlite3.connect(self.DB_PATH, timeout=15, check_same_thread=False)
sqlite3.OperationalError: unable to open database file
The above exception was the direct cause of the following exception:
File "/www/server/panel/class_v2/panel_plugin_v2.py", line 2362, in a
return public.run_plugin_v2(get.name, get.s, get)
File "/www/server/panel/class/public/common.py", line 8357, in run_plugin_v2
res = PluginLoader.plugin_run(plugin_name, def_name, args)
SystemError: returned a result with an exception set
File "/www/server/panel/BTPanel/init.py", line 2604, in publicObject
File "/www/server/panel/BTPanel/init.py", line 2550, in run
File "/www/server/panel/class_v2/panel_plugin_v2.py", line 2364, in a
return public.get_error_object(None, plugin_name=get.name)
File "/www/server/panel/class/public/common.py", line 1307, in get_error_object
result = readFile('{}/BTPanel/templates/default/plugin_error.html'.format(get_panel_path())).format(
KeyError: 'plugin name'`
