Change Log:
- Add Account feature(Currently only supports X86_64 architecture)
- Add Docker One-Click Install (Image Store)
- Adjust Nginx Cache path to: /www/server/fastcgi_cache
- Optimize App Store interface
- Optimize Docker Compose interface
- Optimize panel access speed
- Fix the problem that the language file is empty
- Fix the problem of high CPU usage of BT-Task
Tip: After upgrading, please press Ctrl + F5 to force refresh
This version will be updated to Python 3.12, please read this post before updating:
aaPanel operating environment upgrade to Python 3.12 Questions and answering
If you encounter problems during use:
- Take a screenshot of the error message,
- Provide the operating system and system version you are using and provide feedback to the forum.
