sanhpv aaP_demo1 There is no unusual traffic, only google bot traffic is a lot, my website has 188k articles
aaPanel_Kern Hello, do you use waf? Or CloudFlare checks whether access is normal? You can use phpmyadmin to check which mysql processes occupy the CPU sanhpv
sanhpv It's funny that I have full cpu due to Google bot, now what should I do to block Google bot so I can't do SEO?
aaPanel_Kern Hello, I suggest you check what is the cause? Can it be viewed using Website statistics v2? Which IP is accessed from? If it is not a normal access, you can prohibit it from accessing it. sanhpv
sanhpv aaPanel_Kern I found the cause in this article, can you go to this article and help me? https://www.aapanel.com/forum/d/22555-how-do-i-need-to-set-up-mysql-to-withstand-the-load-of-bot-requests
aaPanel_Kern Hello, is it possible to set it to 2G-4G? You need to restart mysql after setting sanhpv
