• Support
  • not able to generate LE certificate for www
Hello,
i have a doman abc.com which is working perfectly
but later we wanted to have www.abc.com too but when i generate SSL with letsencrypt, it always fails with error.
whereas abc.com is able to generate SSL without any problems.
both pointing to server IP only
what could be the reason? also can i check any logs to find error?
thanks
