• Support
  • Migration from Plesk to AAPanel
Hey guys,
Would like to know what the process would be to migrate plesk to AAPanel. I have the following:
  • Wordpress, Laravel and HTML sites
  • Emails and mailboxes using Postfix
  • Docker with over 8 docker apps
  • Postgresql and Mysql databases
Is the process difficult? Am I able to use the one click migration that you guys have? Will you guys consider a native plesk migrator and is there one in the works? Really thinking of purchasing the lifetime license, but want to make the transition as smooth as possible. I only have one live production physical server and need to figure out every step to make this work without losing data if I decide to move forward.
Please advise, thanks.
    Hello, there is currently no such tool. You can only manually back up the data and then restore the data.
    Deployment needs to be completed before migration and recovery can be carried out
    aaP_universalenvision2011
