Good afternoon!
After updating the dashboard to version 7.18.0 a new problem has appeared, namely with installing/updating WP plugins.
Wordpress works through WP Toolkit.
When trying to load a plugin, it writes the error “Temporary folder not found.”
I haven't figured out what this problem is, everything works fine on version 7.17.0.
Wordpress issue (aaPanel 7.18.0 Beta)
No, I can't figure out what the problem is yet.
Temporary solution is to specify a temporary folder in php.ini
upload_tmp_dir = /tmp
Did you happen to have any cache plugins installed?
notelseit I have caching enabled in WP Toolkit and also have the W3 Total Cache plugin installed.
Disabling the plugin and caching in Toolkit does not solve this problem.
DeZiNsect0r
the problem is the user.ini file that is not modified correctly with the cache plugin settings
