Hello.
I see update link beside openlitespeed in app store and when i click on update it say task add to queue but it show again update link and it can not update OLS.
Please help.
I think it already has the most recent version if you are on 1.16.5
    Hello aapanel managers
    Is there any solution?
    • JAY replied to this.
      JAY try to uninstall and reinstall it
      Hello
      You are an aapanel team member or a user?
      There are several websites and domains if i uninstall and reinstall maybe cause problems?
      Is not there any other solution?
      aaPanel_Jose I just tested that the update is working, please try again
      problem not solved and exist.
      update log:
      openlitespeed/admin/html.open/res/js/plugin/datatables/swf/
      openlitespeed/admin/html.open/res/js/plugin/datatables/swf/copy_csv_xls_pdf.swf
      openlitespeed/admin/html.open/res/js/plugin/datatables/swf/copy_csv_xls.swf
      openlitespeed/admin/html.open/res/js/plugin/datatables/dataTables.colReorder.min.js
      openlitespeed/admin/html.open/res/js/plugin/flot/
      openlitespeed/admin/html.open/res/js/plugin/flot/jquery.flot.resize.min.js
      openlitespeed/admin/html.open/res/js/plugin/flot/jquery.flot.tooltip.min.js
      openlitespeed/admin/html.open/res/js/plugin/flot/jquery.flot.orderBar.min.js
      openlitespeed/admin/html.open/res/js/plugin/flot/jquery.flot.cust.min.js
      openlitespeed/admin/html.open/res/js/plugin/flot/jquery.flot.pie.min.js
      openlitespeed/admin/html.open/res/js/plugin/flot/jquery.flot.fillbetween.min.js
      openlitespeed/admin/html.open/res/js/plugin/datatable-responsive/
      openlitespeed/admin/html.open/res/js/plugin/datatable-responsive/datatables.responsive.min.js
      openlitespeed/admin/html.open/res/js/plugin/msie-fix/
      openlitespeed/admin/html.open/res/js/plugin/msie-fix/jquery.mb.browser.min.js
      openlitespeed/admin/html.open/res/css/
      openlitespeed/admin/html.open/res/css/bootstrap.min.css
      openlitespeed/admin/html.open/res/css/lockscreen.min.css
      openlitespeed/admin/html.open/res/css/font-awesome.min.css
      openlitespeed/admin/html.open/res/css/smartadmin-production.min.css
      openlitespeed/admin/html.open/res/css/lst-webadmin.min.css
      openlitespeed/admin/html.open/res/css/googlefonts.css
      openlitespeed/admin/html.open/lib/
      openlitespeed/admin/html.open/lib/CNode.php
      openlitespeed/admin/html.open/lib/DTblMap.php
      openlitespeed/admin/html.open/lib/jCryption.php
      openlitespeed/admin/html.open/lib/DPage.php
      openlitespeed/admin/html.open/lib/CData.php
      openlitespeed/admin/html.open/lib/DInfo.php
      openlitespeed/admin/html.open/lib/PathTool.php
      openlitespeed/admin/html.open/lib/PlainConfParser.php
      openlitespeed/admin/html.open/lib/CValidation.php
      openlitespeed/admin/html.open/lib/CAuthorizer.php
      openlitespeed/admin/html.open/lib/XmlParser.php
      openlitespeed/admin/html.open/lib/SInfo.php
      openlitespeed/admin/html.open/lib/ControllerBase.php
      openlitespeed/admin/html.open/lib/DTbl.php
      openlitespeed/admin/html.open/lib/LogViewer.php
      openlitespeed/admin/html.open/lib/util/
      openlitespeed/admin/html.open/lib/util/build_php/
      openlitespeed/admin/html.open/lib/util/build_php/build_prepare.template
      openlitespeed/admin/html.open/lib/util/build_php/BuildConfig.php
      openlitespeed/admin/html.open/lib/util/build_php/build_install_ext.template
      openlitespeed/admin/html.open/lib/util/build_php/build_prepare_ext.template
      openlitespeed/admin/html.open/lib/util/build_php/build_manual_run.template
      openlitespeed/admin/html.open/lib/util/build_php/build_common.template
      openlitespeed/admin/html.open/lib/util/build_php/build_install.template
      openlitespeed/admin/html.open/lib/util/build_php/buildfunc.inc.php
      openlitespeed/admin/html.open/lib/ows/
      openlitespeed/admin/html.open/lib/ows/DPageDef.php
      openlitespeed/admin/html.open/lib/ows/Product.php
      openlitespeed/admin/html.open/lib/ows/DTblDef.php
      openlitespeed/admin/html.open/lib/ows/ConfValidation.php
      openlitespeed/admin/html.open/lib/ows/Service.php
      openlitespeed/admin/html.open/lib/ows/RealTimeStats.php
      openlitespeed/admin/html.open/lib/ows/DAttr.php
      openlitespeed/admin/html.open/lib/ows/UI.php
      openlitespeed/admin/html.open/lib/DAttrBase.php
      openlitespeed/admin/html.open/lib/blowfish.php
      openlitespeed/admin/html.open/lib/DMsg.php
      openlitespeed/admin/html.open/lib/DKeywordAlias.php
      openlitespeed/admin/html.open/lib/DAttrHelp.php
      openlitespeed/admin/html.open/lib/DTblDefBase.php
      openlitespeed/admin/html.open/favicon.ico
      openlitespeed/admin/html.open/index.php
      openlitespeed/admin/html.open/login.php
      openlitespeed/admin/conf/
      openlitespeed/admin/conf/php.ini
      openlitespeed/admin/conf/admin_config_ssl.conf.in
      openlitespeed/admin/conf/admin_config.conf.in
      openlitespeed/admin/misc/
      openlitespeed/admin/misc/uninstall.sh
      openlitespeed/admin/misc/php.ini
      openlitespeed/admin/misc/lsup.sh
      openlitespeed/admin/misc/create_admin_keypair.sh
      openlitespeed/admin/misc/lsws.rc.gentoo.in
      openlitespeed/admin/misc/gdb-bt
      openlitespeed/admin/misc/lsws.rc.in
      openlitespeed/admin/misc/build_admin_php.sh
      openlitespeed/admin/misc/admpass.sh
      openlitespeed/admin/misc/genjCryptionKeyPair.php
      openlitespeed/admin/misc/testbeta.sh
      openlitespeed/admin/misc/convertxml.php
      openlitespeed/admin/misc/convertxml.sh
      openlitespeed/admin/misc/lshttpd.service.in
      openlitespeed/admin/misc/htpasswd.php
      openlitespeed/admin/misc/lscmctl
      openlitespeed/admin/misc/gzipStatic.sh
      openlitespeed/admin/misc/rc-inst.sh
      openlitespeed/admin/misc/rc-uninst.sh
      openlitespeed/admin/misc/enable_phpa.sh
      openlitespeed/admin/fcgi-bin/
      openlitespeed/admin/fcgi-bin/admin_php5
      Openlitespeed web server exists, will upgrade.
      install.sh: line 67: ./_in.sh: Permission denied
      [31mYour webAdmin password not changed.[39m
      [OK] Send SIGUSR1 to 31428
      sed: no input files
      sed: no input files
      [OK] Send SIGUSR1 to 6521
        In fact, OLS has been updated to the latest version, but the version number file has not been modified
        I have manually changed it to 1.6.15 for you and will fix this problem in the panel
        You can check the version through the command line /usr/local/lsws/bin/lshttpd -v
          I update my CentOs once in a while by (yum -y update). maybe it cause this problem?
          once,I saw it updated OLS by (yum).
          Stealth
          Because the lsphp73 version of OLS is 7.4.9, and our php package has been updated to 7.4.10, we will always prompt to update. Let’s see how to deal with this problem.
          @arsse
          This problem is not caused by yum update
