In fact, after stopping the node process in the Node Website section, the PID process was still active, using your "Task Manager" plugin I can kill it, and then start it again from the Node Website position, this will probably solve the problem.
Some commands do not work because I have Ubuntu
Server load after reboot is still acceptable. It averages 25% for core.
Despite everything, after the reset the panel still does not turn on.
Kern, if you have time I can give you the details to my server, then you can check it out.
