That's the problem, I couldn't make a local connection on the current server. For example, I click Connect to phpmyadmin from the Database list and the page doesn't work: it doesn't enter port 888. The port is active and working.
Externally, in my software, I can't get a smooth connection as localhost in the config.php file. localhost:3306 fixes it.
