I solved the cache problem adding those lines on the nginx config 🙂
location / {
proxy_pass http://127.0.0.1:4444;
proxy_set_header Host $host;
proxy_set_header REMOTE-HOST $remote_addr;
add_header X-Cache $upstream_cache_status;
#no cache !!!!!!
proxy_no_cache 1;
proxy_cache_bypass 1;
add_header Cache-Control "no-store, no-cache, must-revalidate, proxy-revalidate, max-age=0";
# End of cache :]
proxy_connect_timeout 30s;
proxy_read_timeout 86400s;
proxy_send_timeout 30s;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
# End of HTTP reverse proxy related settings
But the panel still has the problems with the process, if i stop the nextjs project, it wont stop.
