aaP_info_philongland I have fixed this error. Because I installed Nginx free firewall 5.0, it was blocked. Is there any way to make Nginx free firewall 5.0 not block SSL settings?
aaP_info_philongland aaPanel_Kern It seems like the SSL installation error is not coming from Nginx free firewall 5.0. I just tested on a newly installed vps, without installing Nginx free firewall 5.0, SSL cannot be installed.
aaPanel_Kern Hello, check the specific error report. The installation of SSL has nothing to do with the Nginx firewall. It may be caused by an error in the configuration file or the lua module is not installed successfully. aaP_info_philongland
aaP_info_philongland aaPanel_Kern Hello, I have an error of not being able to register SSL on version 7.0.12 again, here is what I learned from the previous version 7.0.11. I don't know why I can't access the SSL registration file. On websites that can register SSL, when accessing the file directly, there will be a downloaded file, and no error message appears? I have added /.well-known/ to the firewall but still can't access it. Refer to the image for more information. Note, only when you can access the SSL registration file can you register, if you can't access the file, you can't renew SSL.
aaP_info_philongland aaP_info_philongland The error of not receiving https after renewing has been fixed, it seems the error comes from DNS. Currently, there is only the problem of not registering a new SSL or renewing the website. I don't understand why I can't access the verification file but it shows 404.
aaPanel_Kern Hi, can you give us your aapanel information? The server makes a snapshot backup first, if possible, please send it to kern@aapanel.com. It is recommended to fill in the following Post link: SSH IP address, account password and port: aapanel login link address and account password: Detailed problem description: No post link will not be able to know which user's information is, and the problem will not be processed aaP_info_philongland
aaP_info_philongland aaPanel_Kern I found the solution and fixed the SSL registration problem myself.
