aaPanel_Kern Hello, it is recommended that you restart the related projects. If it cannot be stopped, it is recommended that you manually kill the related processes. aaP_mdestafadilah_simrs
aaP_mdestafadilah_simrs aaPanel_Kern I do, but sometimes its' not work. how kill the process? if i use nodejs and pm2 together?
aaPanel_Kern You cannot use these two plug-ins at the same time, but you can use the pm2 command to start the project in the node project Try to use the command to kill related processes aaP_mdestafadilah_simrs
