aaPanel_Jose trustdee This may be caused by the fact that the virtual environment is not installed. Please try to execute the [virtualenv] command in the terminal to see if there is an error message
aaPanel_Jose trustdee The command works normally. Have you tried deleting the item and then recreating it?
aaPanel_Kern enot Hello, use the command to enter the virtual environment and manually install xxx to represent related modules md5_env/bin/pip install xxx
