Hi
aaPanel 7.0.11
Debian 12
When I logged into bt panel about a week ago I noticed that it was running at 100% CPU.
top showed btpython (up to 4 instances of btpython running at the same time) was using excessive CPU, rebooting fixes the problem temporarily
According to journalctl btpython is also sometimes using all the RAM
Upgraded to aaPanel 7.0.11, problem still happened. The only other thing I have done during the past week is upgrade the mail server to 5.4.5 from 5.3.x
killall btpython also works but only temporarily
Renaming breaking_through_check.py had no effect:
cd /www/server/panel/script
mv breaking_through_check.py breaking_through_check.py.old
I also stopped all 4 cron jobs in aaPanel that were setup by the system, I then rebooted.
The problem is still happening, it seems to happen every hour on the hour, eg. 2am, 3am, etc
