Hi,
I see some misalignment between the open ports on the System Firewall screen on aaPanel and the list of open ports through ufw status
on my ubuntu machine
the ufw status
command shows more than what is visible on aaPanel. E.g. ports listed after the aaPanel installation (20, 888) to tell the user "if you have issues accessing the aaPanel on port...try with one of the following"
Thanks and regards
