After the update the Docker tab disappeared. On two different servers...
And the offer to update keeps popping up, even though the version is supposedly already the latest one.
The server was rebooted
    Same here, the Docker tab disappeared. I also rebooted the server and restarted aapanel, which didn't help.
      Cron tasks stopped running, curl related error is displayed. connection refused port 443
      UPD:
      Found the problem. After the update Nginx 1.25.5 crashed, after forced start everything more or less worked.
      This problem is not fixed.. I still have this issue and also, there is a conflict apparently with my cache plugin flyingpress..
      hello, I am on Ubuntu, I am using latest node version, for some reason, when i click on stop or restart on a active node, it doesnt kill the processes, it just tries to add a new one which makes it fail because the port is already in use by previous process..
      Hello, thank you for your feedback, we will optimize it.
      9 days later
      What version of NGNIX should I put on aaPanel 7.0.11 with Ubuntu 24.04 LTS for stable operation?
      19 days later
      i have renewed/reapplied letecnrypt certificate to my domain but it is showing old one. I have already tried disabling and renewing by deleting the cert files from following directories
      /www/server/panel/vhost/cert
      /www/server/panel/vhost/letsencrypt
      /www/server/panel/ssl (already empty no files are there)
      and also tried in incognito mode but still same
      aapanel version: 7.0.11
      os: Ubuntu 20.04.4 LTS
