• Support
  • Websites not working with the www prefix using Cloudflare SSL
Hi guys, recently I have been experiencing that my sites just work with the root domain and not with the www subdomain prefix. A few days ago they were working fine, but recently using the www prefix send a Cloudflare host error 526. They mention to check something with the vhosts in aaPanel, but I don't know where to find that. Anyways, if someone else experienced the same and solved it, please let me know. Thanks.
    Hello, I suggest you check what the SSL mode of CloudFlare is? Try changing it to Full
    Also check if the website's SSL certificate matches the domain name?
    aaP_cloud6
      Hello, I checked the Cloudflare SSL and it was in Full strict, I changed it to Full. But nothing happened. My site works perfect without the www prefix but with the www.mydomain.com is not working. The DNS records are okay, the CNAME for the www is correct.
      As I mentioned it was working before the last update of aaPanel. Any ideas?
