Hello, is the problem solved? Please check whether the hard disk space of the server is normal?
df -h && df -i
aaP_imannurdian7
I'm sorry admin, how do I log back into the AA panel? But my website is still running, only access to the AA panel is like the picture above?
    what is ssh like? I previously changed the settings from https:// to http:// ...how do I open and log back in to puuty?
      Hello, you can also connect to the server's SSH using puuty, or you can use VNC in the server provider's backend.
      aaP_imannurdian7
      please help me and give me a script so I can log back in with putty and fix the access to log in to the aa panel? with problems like the picture above
        Hello, it is recommended to ask the server provider to help you. We also do not have your ssh login information.
        aaP_imannurdian7
