aaP_sudhanshu.shekhar Hi, I have around 300 websites that I need to delete from my aapanel. All of them share the same document root. Is it possible to delete them in bulk? Either using API or Command line?
aaPanel_Kern Hello, yes, it is recommended to delete the snapshot after backing up the server. When deleting, check Document Root, Database. aaP_sudhanshu.shekhar
aaP_sudhanshu.shekhar I couldn't follow. I have several websites. How do I select website profiles? I am afraid your instructions are not clear.
aaPanel_Kern Hello, deleting the site will automatically delete the site configuration. There is no command to delete sites in batches We suggest you tell us how you created your site aaP_sudhanshu.shekhar
