ImportError: /lib/x86_64-linux-gnu/libresolv.so.2: file too short
PLEASE HELP ME TO FIX THIS.
Hello, is it possible to try to repair libc6 using the command line?
sudo apt-get update
sudo apt-get install --reinstall libc6
aaPanel_Kern unable to login in ssh
Hello, what error message does it prompt when unable to log in? Is it possible to use VNC from a server provider?
