aaP_djwayne1985 hi can someone help with the following issue since the panel update i am unable to disable the public access url to improve security if there is a fix for this plz let me know thanks in advance
aaPanel_Kern Hello, are you using openlitespeed? If it is not supported temporarily, You can also use your system firewall settings to only allow 127.0.0.1 to access the port used by phpmyadmin aaP_djwayne1985
