Hello, I upgraded to the latest Aapanel and my SSL certificates stopped working. I'm using Cloudflare 15 year origin certificate and key, worked fine before the upgrade.
I have tried deleting the certificate and key, created new certificate and key pair (both are Cloudflare 15 year Origin Certificate and Key), re-adding them back into panel. If I use ECC encryption to create the Cloudflare certificate and key then the panel won't even let me save the certificate and key, so I used RSA, aapanel can save this but it shows "null" as certificate brand, before the upgrade of aapanel to the latest version, the certificate brand used to show "Cloudflare".
I used one of the Cloudflare allowed port numbers and changed the port number in aapanel settings, it can access the panel using IP address and this port number. BUT, when I added the domain name in the panel, and tried to access the panel using "domainname: port number", it shows SSL certificate invalid. I'm using "Full Strict " mode in Cloudflare as it is the 15 years origin certificate I'm using. So now in order to access aapanel, I had to SSH into the server and did the "bt 12" to unbind the domain.
What is wrong? Does Aapanel latest version work with Cloudflare 15 year origin certificate and key?
