At the same time, check the postfix configuration, which can be viewed in the server status
Put:
Change to:
or
If the display is not OK, try to save the SSL certificate again, or please re-apply for SSL
Unable to send dkim headers
Prompt for permission issues:
systemctl restart rspamd
Use this website to check whether the records of DKIM and SPF are correct?
https://www.dmarcanalyzer.com/dkim/dkim-checker/
https://dnschecker.org/spf-record-validation.php
https://www.mail-tester.com/
Check blacklists
https://mxtoolbox.com/
Sending to gmail needs to configure SSL, do DKIM, SPF, it is best to let the network provider make the PTR RDNS record of ip
