I use Google Cloud Server and opened the ports in Google Cloud but it still doesn't work. Is there an expected problem in Google Cloud?
root@server:~# curl -k https://www.aapanel.com/script/aapanel_check.sh | bash
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 5818 100 5818 0 0 22619 0 --:--:-- --:--:-- --:--:-- 22550
Bt-Panel (pid 939) already running
Bt-Task (pid 793) already running
webserver 1008 root 7u IPv4 8402 0t0 UDP *:33176
Getting server ip, Please wait...
aaPanel port external network test access failed
For reference only, please test manually!
SSL is enabled, please use HTTPS access
aaPanel Internet Address: https://ip:33176/8c573b99
aaPanel Internal Address: https://ip :33176/8c573b99
When sharing, please be careful to hide your IP address
Server internal 127.0.0.1 test access is normal
-------------------------Disk space usage--------------------------
Filesystem Size Used Avail Use% Mounted on
/dev/root 73G 3.8G 69G 6% /
tmpfs 5.3G 13k 5.3G 1% /dev/shm
tmpfs 2.1G 992k 2.1G 1% /run
tmpfs 5.3M 0 5.3M 0% /run/lock
efivarfs 58k 25k 28k 48% /sys/firmware/efi/efivars
/dev/sda15 110M 6.4M 104M 6% /boot/efi
tmpfs 1.1G 4.1k 1.1G 1% /run/user/1001
--------------------------Inode usage------------------------------
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/root 9031680 110958 8920722 2% /
tmpfs 1272563 4 1272559 1% /dev/shm
tmpfs 819200 636 818564 1% /run
tmpfs 1272563 4 1272559 1% /run/lock
efivarfs 0 0 0 - /sys/firmware/efi/efivars
/dev/sda15 0 0 0 - /boot/efi
tmpfs 254512 25 254487 1% /run/user/1001
Python version: Python 3.12.3
aaPanal version_o: 7.0.9
