snowball I'm under DDOS attack even though i block all ips outside my country. By attackers still request to my website by vpn from data center outside my country So is there any way can i block specific data center using nginx. Thanks for any advices
aaPanel_Kern Hello, this is attack traffic arriving at the server, you need to process it before arriving. You can use CloudFlare or CDN etc. snowball
snowball aaPanel_Kern I'm using server's ip as domain name for my website. So the attackers know my ip server. I can only mitigate ddos attack by waf of nginx or ubuntu
aaPanel_Kern Hello, I suggest you check according to the website logs. It is difficult to protect against traffic attacks. If the server has a security group, you can use the security group for protection. snowball
