No. There is only this one. But now I have another one on the panel when Logging in
`Traceback (most recent call last):
File "/www/server/panel/pyenv/lib/python3.12/site-packages/urllib3/connection.py", line 174, in new_conn
conn = connection.create_connection(
File "/www/server/panel/pyenv/lib/python3.12/site-packages/urllib3/util/connection.py", line 95, in create_connection
raise err
File "/www/server/panel/pyenv/lib/python3.12/site-packages/urllib3/util/connection.py", line 85, in create_connection
sock.connect(sa)
File "/www/server/panel/pyenv/lib/python3.12/site-packages/gevent/socketcommon.py", line 590, in connect
self.internal_connect(address)
File "/www/server/panel/pyenv/lib/python3.12/site-packages/gevent/socketcommon.py", line 655, in _internal_connect
raise _SocketError(result, strerror(result))
OSError: [Errno 101] Network is unreachable
File "/www/server/panel/pyenv/lib/python3.12/site-packages/urllib3/connectionpool.py", line 715, in urlopen
httplib_response = self._make_request(
File "/www/server/panel/pyenv/lib/python3.12/site-packages/urllib3/connectionpool.py", line 404, in make_request
self.validate_conn(conn)
File "/www/server/panel/pyenv/lib/python3.12/site-packages/urllib3/connectionpool.py", line 1058, in validate_conn
conn.connect()
File "/www/server/panel/pyenv/lib/python3.12/site-packages/urllib3/connection.py", line 363, in connect
self.sock = conn = self.new_conn()
File "/www/server/panel/pyenv/lib/python3.12/site-packages/urllib3/connection.py", line 186, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: : Failed to establish a new connection: [Errno 101] Network is unreachable
File "/www/server/panel/pyenv/lib/python3.12/site-packages/requests/adapters.py", line 486, in send
resp = conn.urlopen(
File "/www/server/panel/pyenv/lib/python3.12/site-packages/urllib3/connectionpool.py", line 799, in urlopen
retries = retries.increment(
File "/www/server/panel/pyenv/lib/python3.12/site-packages/urllib3/util/retry.py", line 592, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='www.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftListEn?status=False&msg=Please+login+with+account+first&environment_info=%7B%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable'))
File "/www/server/panel/BTPanel/init.py", line 2520, in publicObject
File "/www/server/panel/BTPanel/init.py", line 2466, in run
File "/www/server/panel/class_v2/ajax_v2.py", line 1793, in get_pay_type
plugin_list = plu_panel.get_cloud_list()
File "/www/server/panel/class/panelPlugin.py", line 426, in get_cloud_list
softList = public.load_soft_list(True if force == 1 else False)
File "/www/server/panel/class/public/init.py", line 8079, in load_soft_list
resp = requests.post(cloudUrl, params=pdata, headers=url_headers, verify=False, timeout=10)
File "/www/server/panel/pyenv/lib/python3.12/site-packages/requests/api.py", line 115, in post
return request("post", url, data=data, json=json, **kwargs)
File "/www/server/panel/pyenv/lib/python3.12/site-packages/requests/api.py", line 59, in request
File "/www/server/panel/pyenv/lib/python3.12/site-packages/requests/sessions.py", line 589, in request
File "/www/server/panel/pyenv/lib/python3.12/site-packages/requests/sessions.py", line 703, in send
File "/www/server/panel/pyenv/lib/python3.12/site-packages/requests/adapters.py", line 519, in send
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='www.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftListEn?status=False&msg=Please+login+with+account+first&environment_info=%7B%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable'))`
