After installation i am getting error. I am very first time setup CentOS9 with fresh setup and installing Mongodb6.0. It's installing fine but getting this error under Database
"An error occurred while the panel was runningļ¼
KeyError: 'plugin name'
REQUEST_DATE: 2024-09-25 09:00:48
VERSION: CentOS Stream 9 x86_64(Py3.12.3) - 7.0.9
REMOTE_ADDR: 174.127.114.129
REQUEST_URI: GET /plugin?action=a&name=mongodb&s=get_databases
REQUEST_FORM: {}
USER_AGENT: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36
File "/www/server/panel/class/panelPlugin.py", line 2258, in a
return public.run_plugin(get.name, get.s, get)
File "/www/server/panel/class/public/common.py", line 8283, in run_plugin
raise PanelError(res['msg'])
public.exceptions.PanelError: An error occurred while the panel was running: Traceback (most recent call last):
File "/www/server/panel/plugin/mongodb/mongodb_main.py", line 19, in get_databases
return json.loads(tmp)
File "/www/server/panel/pyenv/lib/python3.12/json/init.py", line 346, in loads
return default_decoder.decode(s)
File "/www/server/panel/pyenv/lib/python3.12/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=w(s, 0).end())
File "/www/server/panel/pyenv/lib/python3.12/json/decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
File "/www/server/panel/BTPanel/init.py", line 2545, in publicObject
File "/www/server/panel/BTPanel/init.py", line 2491, in run
File "/www/server/panel/class/panelPlugin.py", line 2260, in a
return public.get_error_object(None, plugin_name=get.name)
File "/www/server/panel/class/public/common.py", line 1280, in get_error_object
result = readFile('{}/BTPanel/templates/default/plugin_error.html'.format(get_panel_path())).format(
